- MP29436-A
MP29436-A
Description
The MP29436-A is a 16-phase, 3-loop multi-phase controller that is compliant with VR14.Cloud, IMVP9.3, SVI3 rev. 3.1 and rev. 2.0, and AVSBus rev. 1.4 and rev. 2.1 specs. The device works with MPS and multiple vendors’ DrMOS products to provide a multi-phase voltage regulator (VR) total solution with minimal external components. It can be configured for up to 16-phase operation for rail 1, 8-phase operation for rail 2, and 5-phase operation for rail 3.
The MP29436-A provides on-chip non-volatile memory (NVM) to store and restore device configurations. Device configurations and fault parameters are easy to configure or monitor by using the PMBus/I2C interface. The MP29436-A can monitor and report the output current (IOUT) through the current-sense (CS) output from DrMOS products.
The MP29436-A is based on a unique, digital, multi-phase nonlinear control to provide fast transient response to load transients with minimal output capacitors. With only one power loop control method for both steady state and load transients, power loop compensation is very easy to configure.
The MP29436-A is available in a QFN-60 (7mmx7mm) package.
- 16-Phase, Triple-Loop Digital Controller
- Compliant with VR14.Cloud, SVI3 Rev. 3.1 and Rev. 2.0, AVSBus Rev. 1.4 and Rev. 2.1, and IMVP9.3 Specs
- PMBus/I2C Compliant
- Switching Frequency (fSW) up to 3MHz
- Multi-Configuration via Pin Strapping
- Built-In Non-Volatile Memory (NVM) to Store Custom Configurations
- Minimal External Components
- Overshoot Reduction with Nonlinear Control
- Flexible Phase Assignment for Triple Rails
- Automatic Phase-Shedding (APS) to Improve Overall Efficiency
- Phase-to-Phase Active Current Balancing with Configurable Offsets for Thermal Balance
- Digital Load Line Regulation
- DrMOS Fault Detection, and Fault Auto-Recording to the NVM
- Supports Overclocking Mode
- Line-Float Detection
- Standby Mode to Save Power
- Input Voltage (VIN), Output Voltage (VOUT), Current, Power, and Regulator Temperature Monitoring
- Under-Voltage Lockout (UVLO), Over-Voltage Protection (OVP), Under-Voltage Protection (UVP), Over-Current Protection (OCP), Under-Current Protection (UCP), Over-Temperature Protection (OTP), and Reverse-Voltage Protection (RVP) with Options of No Action, Latch, Retry, or Hiccup Mode
- Enhanced Register Map Read/Write Protection for Improved Security
- Available in a RoHS Compliant QFN-60 (7mmx7mm) Package
MP29436-AGQN-xxxx-Z MP29436-AGQN-xxxx-P MP29436-AGQN-0000-Z MP29436-AGQN-0000-P
MP29436-A Resources
PROCESSOR CORE POWER CONTROLLERSPRODUCT CATEGORY -
MP29508PRODUCTDigital Multi-Phase Controller
MP2891PRODUCTDual-Loop, Digital, 16-Phase Controller with PWM-VID Interface
MP29439-APRODUCTQuad-Loop, Digital Multi-Phase Controller
MP2985BPRODUCTDual-Loop, Digital, 8-Phase Controller with Flexible PWM Firing Order and PMBus Interface for VR14 and Earlier Protocols
MP29612-APRODUCTDual-Loop, Digital, 12-Phase Controller with SVI3 Interface
MP29608-APRODUCTDual-Loop, Digital, 8-Phase Controller with SVI3 Interface
MPQ2931-AEC1PRODUCTDigital LLC Controller with PMBus/I2C Interface, AEC-Q100 Qualified
MP29540PRODUCTDigital, Multi-Phase Controller
MP29816-CPRODUCTDual-Loop, Digital, 16-Phase Controller with PMBus and AVSBus Interface
MP2869APRODUCTDual-Loop, Digital, 16-Phase Controller with SVI3 Interface for AMD
MP2927PRODUCTTriple-Loop, Digital, Multi-Phase Controller with PMBus Interface for AVSBus
MP2880PRODUCTSingle-Loop,20-Phase,DigitalMulti-PhaseControllerwithPMBusInterfaceforAVSBus
MP2882PRODUCTDual-Loop, Digital, 16-Phase Controller with PMBus Interface for SVI2/AVSBus
MP2926PRODUCTTriple-Loop, Digital, Multi-Phase Controller with PMBus Interface
MP2855PRODUCTDual-Loop, Digital, Multi-Phase Controller with PMBus Interface for AMD SVI2
MP2886APRODUCTDigital, Multi-Phase PWM Controller with PMBus and PWM-VID
MP2884APRODUCTDigital, Multi-Phase PWM Controller with PMBus and PWM-VID
MP2853PRODUCTDual-Loop, Digital, Multi-Phase Controller with PMBusTM Interface for AMD SVI2
MP2965PRODUCTDual-Loop, Digital, Multi-Phase Controller with PMBus Interface for VR13.HC/AVSBUS
MP2888APRODUCTDigital, Multi-Phase PWM Controller with PMBus and PWM-VID
MP2953BPRODUCT6-Phase Digital Multi-Phase Controller With PMBus interface for VR12.5
MP2935PRODUCT4-Phase PWM Controller for VR12.5 Applications
MP2932PRODUCT6-Phase PWM Controller with 8-Bit DAC Code for VR10 and VR11
MP2930PRODUCT4-Phase PWM Controller with 8-Bit DAC code for VR10 and VR11
